Problem with 1jz swap
klaasjoe
178
Los Angeles
Hey guys just wondering if anybody else has had these problems. I had Aaron at driftmotion put in a stinger after having too many problems with a greddy emanage and now that the stinger is in the car has a hiccup at 3300 rpms and leans out after 5000. Also the tach only works sometimes. Aaron thinks it is the wire harness being too hacked up. If anybody has any other ideas that would be awesome as I would like to check anything else before buying a new harness and that not working.
thanks, Joe
mkiiichip
1,434
WI
so you have no tune on the new system. i am assuming you did not pay Arron to tune the new ecu. standalone ecu's dont tune themselves. if you are not going to do it yourself, then you need to take to someone to tune it.
or did Aaron say it cant be tuned due to the wiring?
klaasjoe
178
Los Angeles
he took it somewhere to tune it on a dyno but they could only tune it in the low rpm since has the problem with leaning out over 5000 so he just made it driveable. I never got a map on it though
