problem after 550cc installation
QuebecmkIII
50
quebec
I bought the rc 550cc low independance, slight used (about 12000 milles according to the seller but I can say they are very clean) and after the installation the problem start.
I have install new aeromotive afpr and accordian hose at the same time.
All vaccum connect to the same place as before
My idle are fucking rough and it's missing. When I disconnect the spark plug wire on cylinder 5 & 6 (plugs 1 and 5), nothing happen and same thing when i disconnect the injectors connectors 5 & 6.
The coil pack spark on all 6, I check the resistance on connector and injectors and all fine (2.6) an the amp. was .12 to .18
I check my injectors wire, ok
when I disconnect the spark plug wire from the head, he have maybe 1/8'' of oil, is this normal?
Does my 2 injectors are die?
thank
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
always have your injectors flow tested before use.
Check the wiring to the injectors. Also, IIRC resistance on the coil packs should be lower than that, more towards the <.1 ohm
