powerfc help
woodytsi
405
spring,tx
i have the 1jz powerfc ,boost kit and datalogit with the 3bar map. what r u guys doing with the factory map sensor and the wireing for it. do you just delet it.sence the powerfc has its own.
thanks woodytsi
Cam_Ron
53
Calgary, Alberta
I have a ap engineering 2jz power fc that I'm running my 1jz with. From my understanding (haven't tried mine yet) you leave the stock map sensor hooked up and use the white 5 pin connector on the side of the pfc for the other map sensor.
If you want to use a map sensor other than the apex-i upgrade or factory you need to mess around with the scale and offset.
