power window
cartel1_950
supra is gone
Jan 30, 2006
498
calgary
check the switch. mine was the same way and i just replaced the passenger side one and it worked but only using the new switch. i think i have both if you need them
charlesshen
256
orlando
supratoyota18;1021109 said:
i dont have any power going to my window switch?
driver or passenger side most of the time the problem is ther driver side switch cuz it gets the most use this might sound weird but tap the button hard and fast and sometime it well work ive had this problem in all of my supras
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Its not uncommon for the wires to break in the rubber accordion between the door and the body. Moisture gets trapped in there and rots the wires, plus the constant bending of the wires makes them weak and they break. Something to look into after you have tested everything else out...
