I have my battery relocated to the backseat and the engine bay in my supra was thrown together by the previous owner. All the brackets are missing that hold the stock res. in place and the res. itself is missing the mounting brackets. I have a aluminum res that I pulled from an old race car. If i put the res over where the battery used to be but as high up as possible and run the lines right behind the radiator would the pump get enough fluid?? I have electric fans so there is plenty of room for the lines to run to the pump.
