Power Steering, A/C, and Vacumn lines..
Anicrow
108
Colorado
So, I'm nearing the end of my swap and a few things are coming up. The first thing is, I'm looking for a Vacuum line diagram if anyone can point me in the right direction..Can't seem to find one in any of the TRMs that are translated. Oops..Found one http://i3.photobucket.com/albums/y55/Flea420/vac1.jpg
Also, I'm wondering if anyone has a solution to setting up the power steering? If I remember on the 7M it was set up on the other side, so how are you running the lines is there any kind of quick fix for this?
Also, I noticed the connectors for the A/C are a little different, is the best route to just get some custom made, or does some one retail them?
EDIT: So it looks like I found a few answers from Locals here, One says to just replace the old PS lines with the braided one from Driftmotion. For the AC I was recommended to go with the 2JZ Compressor, any other thoughts on this?
Another thought, Is the 2JZ throttle cable the best? Mine actually seems to be too short, I was mentioned something about a Corolla throttle cable too..?
