Possible to swap soarer engine cradle ?
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
I wanted to know if the soarer, say 1990 ish, front engine cradle would be able to fit in the place of the supra front cradle. Would the mounting points line up? I ask because I'm trying to put together a plan involving a front sumped swap, so I figured using the front sump cradle from a soarer would be perfect, but only if it will work with the mk3 supra chassis.
Thanks guys,
eric
edit**
I guess it's also a question of whether the soarer crossmember will swap into place of the supra one. That is the piece which determines front or mid sump I think right?
eric
