Here's a few shots of the plumbing for my GT4088R, how I think it should be run anyways.
The first imagine is of the Oil -TO- Turbo which is the high pressure line to the turbo, the line running -FROM- the turbo out to the pan and finally the two water lines.
The water line at the top of the image will be connected to the neck of the sorta J shaped tube running to the top of the rad.
The second image is simply of a connection on the pump which I am unsure of what to do with. Should I cap it? Where should it be run? That sorta thing.
Thanks for any help and any and ALL suggestions are welcome!
