I'm rebuilding a GE supra no power adders.
Going to be working on the fuel system next. I haven't even touched the fuel system. Dont know the condition, still in the car. Looking ahead for new parts to replace and I came across nightrungarage custom fuel feed line with redium AN fittings.
Their description states: it gets rid of the factory banjo bolt which restricts fuel flow. And it's an OEM replacement due to discounted factory line.
Is this a good thing to replace even with no power adders?
Is extra fuel flow good or bad with a GE build?
Note: replacing fuel pump, fuel pump hanger, fuel level sender, injectors, pressure regulator, fuel filter, and gaskets. All OEM or equivalent.
nightrungarage.com
Mk3 Toyota Supra AN Fuel Feed Line
The Nightrun Garage Mk3 Toyota Supra tank to filter AN fuel feed line replaces your worn-out OEM fuel feed line! Often times the OEM fuel line between the tank and fuel filter is cracked and the fittings are seized together. We assemble high-quality Vibrant Performance line and fittings with...
