Picture request of the stock 1jz BOV vacume lines
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I just need to see a pic of where the 2 vacume lines goto from the stock 1jz BOV. The one that I have apparently doesn't want to work anymore and I don't want to jack up the twins anymore than they probably are. Thanks in advance.
tissimo
Stock is boring :(
Melbourne, FL
Straight line to the top port and the line with the check valve on the bottom port (bottom being bolted to the Intake pipe). If you dont have the check valve, leave the bottom port open
