Passenger side window isn't working all of a sudden
Status
Not open for further replies.
Alec
SP Tuned
Apr 6, 2009
712
Illinois
So yesterday I roll down my windows, and when I go to roll them up, the passenger side doesn't do anything. Drivers side still works. Passenger side make no sounds, no clicking, nothing. It worked perfectly before.
Any ideas? I checked connectors and fuses and they all seemed to be fine. I know it's not the motor because it would gradually go out, not just instantly. Also, if the engine is running, the RPMS don't change at all when I press the passenger side button like it used to, which makes me think it's not getting a signal somehow.
8,898
Does it work from the passenger switch?
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=094
Now that I look at it, I think about the fact that you can lock it out from the driver side. So it can't work from the passenger if it doesn't work from the driver. You can check power at the swtich because that is an easier check than checking voltage at the motor. A broken wire in doors that of cars that are old is not uncommon.
Status
