I've been doing a little here, and a little there. So lately it was time to pay attention to my engine again. I syphoned out nearly five gallons of old fuel and filled her up with five gallons of fresh 93 octane, plus a complete fuel cleaner(just to clean the tank a tad). She started right up and ran strong, I made adjustments to the timing once she reached normal operating temperature and she was doing pretty damn good. She spit a 24 trouble code which was probably due to the recent intake modifications(installed wai). So I drove her around my apartment complex late last night, very nice. Quiet, smooth reving I was IMPRESSED. The first time since I put the engine back together that she actually drove amazingly perfect. I never went passed 3K rpm or second gear(considering I live in an apartment complex you can't really go to fast). So I pull back into my garage, cut the key and pop the hood, check everything out. Looks good, aside from one minor issue. I noticed my battery terminal connector is cracked. These are new 2 guage pos and 0 guage neg battery cables with cheesy terminal connectors. I figured I'd drive the supra to my former Roommates house and pick up the Gold connectors I had in storage there. I get in, and I notice my door lights aren't turning on. Not thinking too much of it, I put the key in, press in the clutch, turn the key. Nothing but a single click from under the hood(I'd say starter tried to turn). Odd, I just drove this car 5 minutes ago and she doesn't have juice? My first assumpting is the positive battery terminal connector. I grab my multi meter for shiggles and check fuses under the hood and under the driver side kick panel, battery voltage(11.82v) and of course the cracked terminal connector which is still holding on firmly to the terminal. Everything checks out except for my doubts in the 11.82 volts from my optima. She use to be shy of 14v and as it stands the car hasn't seen much of any "running" time. I still think the Supra should start with 11.82v. So today, prior to disassembling the broken battery terminal connector, I tried to get in and start her one more time. I noticed I can turn my headlights on and off, yet nothing else seems to have power. I'm going to pick up my gold terminal connectors and prep to change them. Also need to stop at walmart to pick up a new jack so I can change the fuel filter today as well. So in the mean time, anyone have an suggestions or experience with a similar problem? I was pretty happy to drive her last night, now I have to face the dissapointment that i can't tell what's going on with the electrical system.
