I just bought a 1989 Toyota supra turbo. The car is a auto to 5spd swap.
It has a new after market hg plugs wires timing belt water pump. There are the bolt ons intake down pipe exhaust 550 injectors lex afm apexi neo. The problem I am having is the car over heats and the temp gauge is not working.
is the sensor to the temp gauge this? The green plug?
http://www.supramania.com/forums/attachment.php?attachmentid=8096&d=1152589809
I am not sure why it is over heating though the previous owner replaced the coolant and supposedly put a new thermostat in it. It is missing the fan shroud and the under bell tray. I know I need to fix the gauge first to see the temp over heating. The BVSV is broke as well there is no vacuum hoses on the BVSV either. Do I need to fix the BVSV? ( the 2 LIttle nipples are broke)
Any suggestions on what to look for or what the issue maybe
