hey everyone my car has been having problems with overheating, yesterday i only hit boost once and right after that the temp gauge shot up so i pulled over and let it cool off. and drove it to work with no problems. ive already flushed the system with one of those cheap flush kits from walmart. also i thought it was the thermostat so i took off the housing only to discover no thermostat, i dont know why the previous owner took it out or something so i went and bought a new one. im going to go try burping it and see if that helps. cause when i came home from work it was spewing coolant out the overflow tank. i know youre thinking BHG but im sure its not there are no signs, no milky coolant or oil i even had the valve covers off to retorque the head but it was already done. and the oil looked clean. also there is a pretty good sized dent on the intercooler that looked like it was repaired but that is what im going to buy next paycheck. just wondering if that could be the problem? sorry about the long post but thanks for the help.
cliff notes: car overheats, hit boost only one time and temp gauge shot up. recently replaced thermostat and flushed the cooling system with a cheap garden hose kit from walmart. dent in intercooler could this be the problem? coolant comes out the overflow tank as well. oh and also my heater blows cold not sure if this has anything to do with it. thanks for the help again,
Zach
edit: forgot to mention previous owner said it was rebuilt.
edit 2: checked and the fan was not original fan and was cut to fit, also the previous owner cut the fanshroud out to fit the fan in. could this be the problem? anyone have a shroud and fan i can buy? im starting a WTB thread.
Zach
