Well im having a bit of trouble figuring out why I am overheating. I can drive around the city no problem, AC on and everything.. But when I get on the freeway weather the AC is on or off after about 3 min the temp starts climbing and gets into the red. I have been trying to find out why for a week now and trouble shooting and I am leaning towards the radiator. Im sure its not a blown head gasket, No smoke, No milky coolant, Water level and oil level stays the same. Head gasket was replaced 3000-4000 miles ago with a felpro and ARP's torqued to 90ft lb's, Head was machined as well. I have replaced the water pump, Thermostat, back flushed the block and have good flow through it. I am using a Tarus Electric fan on high speed which is sufficient for the application. Anyways, what do you guys think? Thanks in advance.
Thanks,
Devin
Thanks,
Devin
