FYI i tried searching and didnt see anything.
Ok.. so most of you know i was asking on how to set the timing, thanks to the info i got it timed, and running almost properly.
now.. the bad part. the car overheats after 10mins of driving.
-replaced thermostat
-checked coolant
-heater blows cold
Could the VSV be faulty, and could it cause the car to overheat?
radiator appears to be leak free and in decent shape. i ruled out water pump because if the water pump was faulty it would overheat faster correct?
all fans work correctly,
also idles rough(revs nice and drives nice).. could the timing be off just barely enough to cause temp to rise drastically?
and secondly, (off topic question)
my friend put a dvd player in his car for his kids, but its set to only watch DVDS when the park brake is on, Can he bypass this with the accessory wire so his kids can watch it while the car is running?
Thanks guys! i appreciate your help!
-r
thanks guys!
-checked coolant
-heater blows cold
-r
thanks guys!
