outter tire wear
supraman508
496
maryland
what is yall oppion about me adjusting the toe on the front alignment do to my tires are wearing out on the outter wall.just temporarily to i can scrap up money to get a real alignment.It's pissing me off cause i just bought 4 225/50/r16 in febuary.I know about the t.s.r.m but i can't go a day without driving her and i want to read some of your knowledge and lern something.
supraman508
496
maryland
SupaMan;1185580 said:
you sure your not talking about camber? just the way im reading it sounds like a camber problem not toe.
camber would be wearing out the inner side of the tire,not the outter.I think i need to push out the toe,YES
SupaMan
Want The Boooooossttttttt
Oct 12, 2006
1,101
Cape Coral,Florida
camber can be either way theres positive and negitive camber.....
positive camber would wear out the outside of the tire negitive would do the oppisite.
to give you an idea postive camber is when the tire is tilted like this \ negative camber is when its like this /
supraman508
496
maryland
makes perfect sence,and i need to gain some negative camber.
SupaMan
Oct 12, 2006
1,101
Cape Coral,Florida
im not exactly sure on the step by step on how to adjust it yourself youve gotta right on the money with that kinda stuff.
doing it on r/c cars is alot diffrent than real cars which is why i leave alignments up to an alignment shop.
supraman508
496
maryland
You make a good point cause if i try it myself the soup will wana turn left and right all at the same time,l.m.m.a.o
