oil pump question
FP3
san bernardino,ca
hey guys, after much searching i finally have a question. I'm in the middle of building my motor and cant figure out if i want to put a oem oil pump in or a toga high volume oil pump. quick back ground, shootin for 550-600rwhp ish, fully forged internals, ect. thank you guys for any help!!
Pat
spoolint78
Representing T.O
T.O
they are the same from my understanding.
all are aisin.
stock pump shimmed is the only real upgrade.
FP3
san bernardino,ca
thats what i remembered, but i just want to make sure, its been over a year sence ive been around(work,bought a house) and was searching and couldnt find anything on the subject. just gettin back into the swing of things and tryin to see if anything has changed.
thanks
pat
jdub
Feb 10, 2006
10,730
Valley of the Sun
Get an OEM pump (Aisin), make sure it's for a turbo motor (the gearing is different from the NA), and shim the relief valve 4-5mm. Get rid of the stock filter head and switch the cooler system to a full flow, thermostat controlled circuit. That will go a long way keeping your motor happy with oil flow ;)
FP3
san bernardino,ca
cool, thank you guys very much. i read that post before and already planned on doing that. but i was just wondering if it would be worthwhile to get the "high volume" pump. sounds like i'll just be doing the regular pump.
