driver005s;1722140 said:Is this hole where DM oil pressure sender hose goes?
i try to screw it in but it wont fit their
GN_Convert;1723234 said:here is what you need. You can use the stock 7M pressure sender with it
http://store.driftmotion.com/static/i-1jzoilpressuresenderadapterhose.php
A buddy of mine was able to clip the 1JZ harness plug onto the 7M sender.hvyman;1723746 said:Have to use the 7m connector or something similar as well.
Just slipped the clip over the 7M "disk" portion and it locked in place after some encouragement. The 1JZ clip obviously was designed to slip over a tab so it might not be removable now without breaking.hvyman;1723814 said:Take the clip apart and just use the pin?
