oil pressure guage question (7mgte swap)
supraguru05
Dec 16, 2005
737
louisville ky
im going na-t with full gte electronics so basically its just a turbo swap with high compression. the car the motor is going into was originally a NA and im wondering if the voltage gauge will still work since the turbo cars had boost guages there. i know the tach will not work and that i have to order the msd converting thing.
the engine and electronics are going into a 89 and the color of the cps connector is green on the cps and gray on the harness this same color problem occurs on the coil pack as well. however they both plug in i was wondeirng if this is normal for a 89
could a admin change the title to voltage guage
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Uh, you only need to spend 2 minutes swapping a couple resistors. Save the money for something else. If you can't find the details I'll post them later.
supraguru05
Dec 16, 2005
737
louisville ky
i have dr jonez resistor swap guide ill just do that then i assume you can get those resistors at radioshack or somthing
