I'm using a mk3 gauge and a mk3 op sender. The sender worked as a ground when testing another wire supplied with 12v so ground shouldn't be a problem. Also I'm almost positive the sender is fine. Does this mean I can just run my own wire from the sender straight to the gauge and just bypass the wiring from the swap. Seems like it would be simpler and I wouldn't have to guess about what the wire is running through. Only thing is that I believe I tried doing just that before and had no results. I'm just afraid I may have blown my second OP gauge and I'm clueless as to whats causing it and not allowing it to function. My multimeter reads frequency at 20kHz, could I use this to test the reading and what would I look for?
After reading your edited part, I think I may have blown the gauge because with the motor off, acc. on the gauge read 120psi so I may have it grounded. However I have the wire with the connector slid onto the top of the sender so I'm not sure.
