Oil Pans
H-Dogg
125
Watertown, Wisconsin
Can someone explain the difference between the the front sump oil pan and the rear sump oil pan? If what I'm thinking is right, I have the front sump and why couldn't I use that?
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
Its where the sump is, where a majority of the oil is pooled, and where the oil pan pickup is.
Our cars are rear sump, thus meaning the oil "pool" is closer to the rear of the engine.
Big Wang Bandit
Feb 21, 2006
7,551
Er, Oil pan pickup should of read, Oil Pump pickup.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
tissimo said:
you cant use a front sump because thats where the cross memeber sits
:word8kn:
unless of course you have a car that can use a front mount oil pan.
if you want a 2jz to fit in a mkiii supra (or a 1jz) you need the 1jz oilpan from the mkiii supra or the mkiv supra oil pan. mid/rear will work with the mkiii (or hey a dry sump will too!:) )
SupraClaou
846
4
Athens,Greece
Ι got mine (rear sump oil pan) new from Toyota.
You can't make a custom one,cause if you see an oem one
you'll understand why.It is complex,with small brackets,holes
for sensors,oil passages,etc.,it has details and details makes
the difference.Use a Toyota one used or new doesn't matter.
12111-46052 PAN ASSY OIL, UPPER PAN.... 300 euros/ $410 USD
12102-46031 PAN ASSY OIL, LOWER PAN.... 150 euros/ $220 USD
16100-49846 PUMP ASSY,WATER ............. 120 euros / $160 USD
(for those who want the non hydro fan system,& desire the belt driven
fan like all supras have)
13405-46030 FLYWHEEL,SUB ASSY (FROM 1JZ-GTE).....? $$$
(you need this flywheel if you go with the 5-speed R154 transmission
or an aftermarket will do,but still a 1jzgte aftermarket flywheel)
Hope I helped you,even a little...
Good luck on getting the parts
H-Dogg
125
Also, would any of you know if the upper oil pan you can buy off of toyotapartscheap.com is a rear sump oil pan? The illustration pictures it as a front but that wont work for the supra even tho it says it's for a supra!
SupraClaou
846
4
Athens,Greece
The illustration is mistaken.Yeah,believe it or not it's true!
I went at Toyota,gave him the part number for a supra jza80
US spec (rear sump oil pan) and the illustration was showing
a front sump oil pan..:aigo:
But it came as rear sump oil pan,as it should be!
Use the part numbers I have posted before in this thread!
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
ive got a pickup tube w/ strainer and gasket, along with a baffle. all brand new toyota from a jza80, if you are interested send me a pm. i also have jza70 brackets if you are going single, find someone getting rid of a sc300 or MKIV na pan setup.
H-Dogg
125
For a brand new upper oil pan for the 2JZ at toyotapartscheap.com is $281.91 if anyone else is interested! I went by part number so I know this is the right part.
tlo86
Jul 24, 2005
3,914
Colorado
yeah they give great prices, i called toyota and they wanted 200 more. but i bought everything i needed for $150 shipped. and i might just buy a new pickup and gasket thats it
