Oil in Spark Plug holes
Apostle
88
Philly
I recently bought a 87 supra turbo, so I bought a fresh set of new NGK wires and plugs. I always noticed hesitation when I tried to start the car. So when I was changing the plugs I noticed spark plug cyl. #6 was drenched in oil, and #5 had a little bit, the rest were bone dry. Even with the fresh set of wires and plugs it still hesitates a little bit when starting, so I know the oil has something to do with it. Any ideas on what it may be? valve cover gasket? spark plug seals?
spoolint78
Representing T.O
T.O
replace the valve cover seals.
put silicone on the gaskets as well, and new valve cover bolts.
Skam9685
1992 Honda Prelude SI
Jun 22, 2007
157
Oldsmar, Florida, United States
yea mine has I believe to be the same problem as you Apostle....when I just recently changed my spark plugs and wires for NGK the #1 spark plug had fresh oil around it... has the hesitation and all....I had changed the spark plugs thinking it would stop the eradic idle and hesitation...well it stopped the idle jumping just not the hesitation lol
Apostle
88
Philly
Same here awesome idle and better mpg, old plugs were corroded and what not. I'm going to replace the valve cover gasket this saturday, that should fix it. I had the same problem on my celica, after I changed the spark plug tube seals and valve cover gasket no more oil around the plugs. I'm kind of new around the 7m-gte's but I don't think they have spark plug tube seals.
turbo soup
17
MD
yeah i just recently noticed when i fire up the supra it idles rough like vibrates and shakes the whole car, after giving it some gas it mellows out, i just recently got iridium plugs and msd wires ill let you guys know how it goes
