Oil in coolant.....
Cya
628
Columbia, S.C>
and none in pan, WTF....I just put a cometic on im hopping its not the case. Any opinions?? Im thinking it may be a clogged oil filter since it leaks pretty bad when I turn it on.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Cya said:
Oil in coolant... none in pan...
I think you've got your problem right there... :eek:
Even if it were caused by a clogged filter I can't think of anywhere else where the oil could get pushed into the coolant passages.
How much oil are we talking about anyway?
CRE
Oct 24, 2005
3,485
Denver, CO
Cya said:
:wtf: DAMN! The only other time I'd ever heard of something like that was back in high school when a complete idiot poured oil in his rad. Unfortunately I can't imagine anywhere else (besides the HG) where that could happen. Any coolant in the oil pan?
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
you didnt like... mix up your oil and coolant lines on the turbo or something did ya? cuz god damn, four quarts? Good luck with whatever it is, sounds like a nightmare
CRE
Oct 24, 2005
3,485
Denver, CO
^^^yep, forgot about the turbo lines... Don't know how you'd do it unless you've run custom lines.
Cya
628
Columbia, S.C>
im hoping a cloged filter since i pouerd four in and nothing was in the pan.
I went and played w/ it today some more today and oil was shooting from the dip stick!!!!
CRE
Oct 24, 2005
3,485
Denver, CO
You've got to be kidding. When you add oil to the engine most of it runs down into the pan via the crankcase vvent hose... so unless you've decided to run your coolant lines in a VERY interesting way your HG didn't seat... at all.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Yeah I have no idea how this can even happen... it's strange like you reversed the flow of coolant and oil through the passages in the head or something... lol
I hope you figure it out...
Cya
628
Columbia, S.C>
found one leak....the hose from the valve cover to bottom has a crack in it. So far the oil looks fine after checking under the valve covers and dip stick, although I did find that it is slightly over filled. Im draining the coolant as we speak.
