oil clean up
VA7MGE
115
Virgina Beach
any one have suggestions on how to clean off oil from my drive way?
i did my first oil change today and it was a pain to get the filter off, but other than that i now how a big oil stain in the driveway and my parents want me to clean it off. so far I've tried this stuff called purple power its a degreaser/cleaner. i let it sit on the oil stain and power washed it theres still a little bit of the oil. now it doesnt have that rainbowy(chemicals) crap washing away.
any suggestions?
VA7MGE
115
Virgina Beach
noah89t said:
neurotic acid is supposed to work well, let us know what you end up using though
where can i find some of this acid? im going to ask the guys at my local auto store if they dont have anything ill try home dept or lowes
AJ'S 88NA
2,419
Florida
It's Muratic Acid. Sold at any store that carries pool supplys, Home depot even carries it. Be careful with it as it will burn you and do not get close enough to inhale the vapors.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
I hear lysergic acid works too ;)
Brake cleaner will do it if it hasn't set. Muriatic acid will do it if it has. Plus there are several commonly available products made for the job. Good 'ol pressure washing has always worked for me. Google around. The internet isn't just a global pornography network you know...
edit: AJ beat me....
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
Purple power is a pre-diluted degreeser. You need a pure degreeser...might be a little hard to get as those are mostly industrial grade chemicals. The acid will work but it will bleach your driveway lol. And don't let any of that stuff get on you or your car!
cuel
1,536
Baytown, Texas
Find a restaurant goods wholesaler, and look for "Solves It." best full strength degreaser I've used.
I like that.... neurotic acid. Thanks for the laugh.
KicknAsphlt
Occasional Peruser
If you have a Harbor Freight nearby, buy the yellow Heavy Duty Degreaser with the green text on the bottle. You're supposed to dilute it like crazy for general purpose degreasing, but if you dilute it to 50/50, it works like crazy. I was messy working on the truck one time with brake fluid, and I sprayed that shit on there with that dilution ratio, and it pretty much wicked the fluid out of the pavement all by itself. There were even clean spots where the brake fluid were...LOL!
Jeff Lange
Administrator
4,927
19
Sunnyvale, CA
jefflange.ca
There's no need to post your posts in weird sizes/fonts/colours. We have different themes on the site and it can mess up viewing it for others. It usually works best for accenting something, and not for an entire message.
VA7MGE
115
Virgina Beach
ok ill make sure not to post like that again.
about the harbor freight there is one i just need to find out where its located will thanks for the help
5
not a fan of the acid as it leaves worse marks...
there are plenty of good products that will wick it out of the concrete, look around for specifics...
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
DFW
We used to have a Jeep Cherokee that had a bad rear main leak. Anyway, while putting a new head on an 85 Honda Civic in the same spot we used to park the Jeep, gasoline dripped out of the fuel line overnight and covered that whole area of old oil from the Jeep. Well, after spraying off the gas it took every single bit of oil off the concrete and I could not tell there was ever any there.
Now I'm not formally suggesting you do that but it happened merely by accident with me and worked great! ;)
BTW, Muratic Acid is EXTREMELY dangerous. It will melt your skin off and the fumes are very toxic. If you go that route be very very careful. I've seen a couple of Muratic Acids accidents in my paramedic career and it wasn't pretty. It was disfiguring.
