I had areally bad welch plug experience the other day on teh Supra. Replaced a ehad gasket a couple of weeks ago, laminated gasket and ARP studs. Had a welch plug fail on me on the way home at highway speeds ona back road.
I didn't catch it on the gauge in time, first warning I had was temp gauge at red almost instantly, then mondo smoke from burning coolant. The steam was hot and fast/concentrated enough that it MELTED the PVC insulation tape off the ground wires bolted to teh intake manifold, and engine heat MELTED the spark plug boots to the plugs. I had to destroy some boots/leads to get them off. No coolant in the oil or vice versa.
However, would you believe it still has good compression numbers (cold), ran with a glass smooth idle once it cooled down and has good oil pressure still.
I have my fingers crossed, but will not know if it survived till I fix the welch plug and run it back up to temp. I am saying 50/50 chance, but I think I am optimistic.
I was very cautious with the head gasket swap, lots of time went into it, I even replaced one welch plug that looked dodgey and had been weeping a little! Should have done them all I suppose.
I don't really want to yank the head again within a month. I think I'll be paying someone this time.
Regards, Andrew.
Regards, Andrew.
