I had been having a miss under hard acceleration so I changed the gap on my plugs from 31 to 28. The miss was gone. While I was at it I shimmed my wastegate about 3mm.
On my test drive I gradually allowed the engine time to heat up then punched it in a straight away from about 30. The car pulled like I expected and got up to 90 very quickly and smoothly with no miss. At the end of the straight away I came to a stop. The car idled normally. I turned and headed for home, a little low on gas. About a mile down the road the car just dies. I figure it is just out of gas and as luck would have it I was close enough to coast into a gas station and push it up to the pump. I filled up and the tank only needed 13 gallons, 5 gallons short of it capacity. I checked the codes.
At first I got a 31(MAF sensor). I checked the plug, and cleaned it off then re-plugged it in. I cleared the ECU and cranked the car. It ran but with the CEL on. I checked the codes again and got a 24(Air temp sensor). I cleared the ECU again and headed for home. As I come to my next stop the car dies again. It cranks right up without hesitation and off I go all the way to the house with no more incidents. When I get home I check the ECU and get no code. The car idles fine and runs smoothly.
What could cause this? I checked all of my connections and everything that I did and everything was back exactly the way it was supposed to go. Is this the sign of something failing or is there something that I can do to fix to prevent this from happening again?
All help is appreciated.
