o2 Sensor
jammasterstan
Cincinnati
I have been using this guide to help me as much as possible but I have run into a problem, the o2 sensor. like the guide says I went out and got 4 thread in o2 sensors off of escort's at the local junkyard (same as the mustang) but I cant find the wires that their talking about, I know about the signal wire because my old bolt in o2 sensors had just a single wire, the signal. So what Im asking is could someone link me or show me a picture of which connector the other 2 white wires are supposed to connect up to? please?
I have an 88 supra that im dropping a 2jz-ge out of a sc300 into
The guide - http://www.supramania.com/forums/showthread.php?t=63998
The o2 sensor thread - http://www.supramania.com/forums/showpost.php?p=1018140&postcount=195
My o2 sensor - http://i33.photobucket.com/albums/d64/jammasterstan/o2censor.jpg
scottiedawg66
Bay Area Ca
be careful! the sensor grounds itself by being bolted into the exhaust, i crossed a one of the heater wires with the signal wire and had to solder a new component into my ecu. I recommend just getting a new 3 wire sensor and not having any trouble to years / fried ecu.
jammasterstan
Cincinnati
I know which wire is the signal wire ill have to cut off the old connector and solder on the old 2 bolt connector but I dont think ill have a problem with that, Ill let you guys know how it goes.
