O2 (Code 21) or ECU problem?
r45marsh
Old MotorHead
Sep 22, 2007
57
Huntsville,Alabama
I'm just finishing the wiring on my 1JZ. Have a problem with O2/ECU. It's been running very rich and fouling the plugs & O2 sensor. It continuously throws a code 21 - O2. It is impossible to confirm that it clears, because as soon as the key is turned ON, the code (21) is present.
All O2 wiring has been triple checked, O2 replaced, voltages checked. Old and new O2 both have signal output within specs when warmed up. Positive voltage present on O2 heater circuit as soon as key ON. It never gets a signal ground from ECU to actually energise the heater circuit.
Dr. Tweak told me he doesn't think the ECU will throw a code 21 (O2) just because the heater circuit between the ECU and the O2 is bad. He was not positive, but said he thought that the actual signal from O2 to ECU has to be missing.
Looking for confirmation/second opinion. I trust Dr. Tweak, but have no way to confirm. I would appreciate confirmation from other owners and possible solutions.
