O/D light blinking?
ggeiss240sx
82
Laramie, WY
Never really had my supra at high speeds since i got it but i recently took it ont he highway and when I put it in O/D the O/D light blinks constantly. The torque convertor feels like its having a really hard time locking and releasing because it will studder alot when I push the gas pedal down to pass someone. But at normal cruising it feels fine and above 75mph its smooth. Anyways, can anyone shed some light? Thanks much!
-Gary
PS - I tried to search but get impatient after the 6th page....
Suprastic
727
Manitoba
a blinking O/D light indicated that yor are thowing codes. Check it just as you would with the engine light and chech your codes
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
My dad put a supra transmission in in his v6 toyota truck and it blinks the od light. Been like that for 6 years now with no problems. No codes either.
ggeiss240sx
82
Laramie, WY
It doesnt blink like its throwing a code, you know, like the typical X amount of blinks, short pause, another X amount then long pause. This is just a constant blink, on off on off on off(and only in O/D), never changes speed or time.... How do I check tranny codes?
billspreston01
555
North Carolina
maybe it's just warning you that the O/D is off? My o/d light blinks sometimes too....but I did a 5spd swap so it's not even connected to anything :) I'm just gonna pull the bulb out.
Good luck!
N
NDBoost
Guest
werd,
check your engine codes..
Satan
Tampa
I can't remember without looking, but you need to have the overdrive button on, then jumper the tranny-terminals in the diag box... kinda like you would for the check engine light.
Look at the TRSM... specific instructions and what the codes mean...
I've had a code 61 (#2 speed sensor) for some time now, but haven't gotten too far into troubleshooting it.
mk3713
Up for sale
Nov 29, 2005
97
Houston
I am reading about this on Ondemand and when it blinks it means there is a fault code. The ect ecu has stored fault codes. The ect ecu controls solenoid openings for sol.1 and 2 no 1 for shifting no.2 for torque converter lock up. To retreive fault codes put a jumper wire on TT and E1 on check connector, with OD switch on and ignition switch on.
#42 Defective no 1 speed sensor
#61 Defective no2 speed sensor
#62 Defective no 1 solenoid
#63 Defective no 2 solenoid
#64 Defective lock up solenoid
Use this to trouble shoot
Satan
Tampa
Getting ready to troubleshoot mine today... Was hoping to see that someone else may have figured out their issue. Anyways, I'll report back on what I find...
8,897
The blinking O/D light is an indicator of a fault. You need to retrieve the DTC's as indicated on the TSRM online.
On another note, there isnt a reason to drive with the O/D button deactivated. There are only a few instances when you should have it off. The old GM 700R4 renamed 4L60E was better if you drove it that way due to the overdrive sprag failing. We dont have that problem. All you are doing is wearing out the button and switch.
A studder when rapidly acclerating could be an ignition problem. Be more descriptive when you decribe the drive problem.
Jetfixr757
Sleeper
Cocoa, Florida
You can still run but the tranny will just shift at default. If your speedo cable is broke the light will flash. Mine was the short one. Less than 25 bucks.
William 89T
miggles
i wasnt speeding officer
Jun 3, 2005
526
perth West Australia
my 2nd a340e install would cause the OD light to blink constantly.Trouble shoot and it would come up as 2nd speed sensor.Had no idea on how to repair it so i kept driving untill it died,got another one and it blinked again.Got a maual in it now and no more blinking :D
Satan
Tampa
Speedo's fine and everything else check's out... just no signal from the speed sensor, to the ABS computer. I will pull the sensor off again this week and see what's up with it. I already swapped it before with another known-good one, but still had the code.
