not starting
s7mgte
136
ny
i had a small drip from the cam cover by the turbo that dripped on the exhaust manifold and burned.. soi took the cam cover off and whatnot and put some sealant on it and reinstalled everything.. i go to start the car and now it wont start..i took the cam position sensor out also to see if the o ring was good. checked it to make sure it was aligned numerous times and now all the car does it turn over with nothing.. im getting aggravated? any ideas?
NewWestSupras
SoupLvr
Mar 1, 2006
611
White Rock
Check the wires from the cps to the harness side. Even if they look good, wiggle them and see if there are any breaks internally. Its probably wiring.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,281
71
Atlanta
Werd- The CPS's wires and the alignment of the unit itself prolly make up 75% of all no-start issues for these engines.
s7mgte
136
ny
well see the thing is the female connector of it broke in half so i just have the 4 little pins sitting in there and then plug in the male part from the harness and its always worked.. i mean at this point i really dont know how to check to make sure the wires are correct or not.. i dont see where they could be loose.. driving me nuts.. i know the cps is aligned right sooo it has to be somethin with wires.. im confused though.. because its always worked before
james_9876
Rehabilitation time...
Aug 1, 2007
183
Spartanburg, SC
you wont like my answer, but idc.
take the timing cover off and line the cam gears up with the crank. Line the CPS up and reinstall it. If it's not a wiring probably then it will crank up and run.
s7mgte
136
ny
all that is setup perfect.. ive done that before too set the cam gears where they should be with the crank at zero
s7mgte
136
ny
gnarkill87 said:
then its your wiring for sure. have you checked for fuel and spark?
ha i figured it out.. im retarded.. i put the cps in all good and whatnot.. just i didnt crank the timing around back to 0 when i put that back in.
