How to use your dyno graph to shift.....
For instance, your peak hp is at 5500rpm. What you have to look at is, where the rpm will be when you shift to the next gear. You already know that past 5500rpm your dropping power. So when you shift to the next gear and the rpm falls to say, 4500rpm, is the power there higher than the power at the other end of the rpm past 5500rpm where you shifted at.
4000rpm 180hp
4500rpm 200hp
5500rpm 250hp
6000rpm 225hp
6500rpm 195hp
If you shift at 6000rpm, rpm will drop to 4000rpm. Hp at 6000rpm is higher than 4000rpm, so you don't want to shift yet. If you do, your accelerating with less hp.
If you shift at 6500rpm, rpm will drop to 4500rpm. 4500rpm is making more power then 6500 rpm. So you want to shift before 6500rpm where hp is less than the next gear. So you might want to shift at 6300rpm.
You always want to shift where the next gear will have equal to or more power than the current gear, unless your at redline and have no choice.
Just my rambling..... :bigthumb:
