No windows and gauge cluster plz help!
S.A. supra
2,405
Buda, Texas
I was working on something and I moved my seat all the way up and I pinched the wires under the seat. It would trip a little breaker where the fuses are drivers side foot panel.
---------- Post added at 07:19 PM ---------- Previous post was at 07:11 PM ----------
You can reset the braker by sticking a pin in the center of it. if it keeps tripping its a wiring problem.
---------- Post added at 07:28 PM ---------- Previous post was at 07:19 PM ----------
Are your seats working
917mgte
115
butte mt
seat is working i have gauge cluster lights just no fuction. No working windows i checked that gauge fuse and its fine.
917mgte
115
butte mt
So i decided to take a closer look and now the fuse for the gauge cluster fuse was no good. I replaced it and nothing no power to fuse box at all. All the wires are dead for the windows. hmmmmm what could have i done lol
Did you just check that 1 fuse? Check them all. A test light or multi meter would be better than pulling each one out or trying to eyeball them.
917mgte
115
butte mt
I checked the gauge cluster fuse that and the windows are the only ones that arent working i used a multi meter to check the fuse . Thats how i found that the gauge cluster fuse was blown. I replaced it and still nothing took a stab light to the fuse box and everything is hot minus the gauge cluster?? The only thing i did was take out the ecu and fished out the wiring harness and ran the line and wire for the profec. Installed it all again wired in the profec to the cd player (still works btw) and went to go pick up somemore vacuum hose (Everything was working on the way there) Then i shut the car off and the gauge cluster and windows were dead.
917mgte
115
butte mt
So today i figured out that it only blows the fuse when i put the car in reverse. Is the gauge cluster,windows heater and reverse lights all on one circuit? Any info would be great!
Ya its all in the wiring behind the dash and goes to the engine harness body plugs.
They all share the gauge fuse. If thats the fuse your blowing then you have wired something wrong or pinched a wire and its grounding out. Something you did caused this.
917mgte
115
butte mt
Alright so i will tear into the wiring tomorrow and see what i managed to do. Thanks for all the answers if anyone has something else plz feel free.
