No RPM, No Oil Pressure, No check engine light
JB91389
decisions...decisions...
Jun 22, 2006
698
Ottawa
Hey everyone,
All of the above worked before.
I just completed my 5 speed swap on my 87 supra. The car starts fine and seems to idle fine. However, there is no RPM signal, No Oil pressure showing on the gauge, and I am not able to look for codes because when I bypass the terminals, the check engine light does not even come on.
I check all the clips and they are all secure.
So now I'm assuming it's a wireing problem, but where would be the best places to start?
Thanks
89supra7mgte
797
colorado
the tsrm for diagram. check the harness around where you added the clutch pedal bracket and what not. may have a pinched wire or two. have you checked fuses?
JB91389
Jun 22, 2006
698
Ottawa
Found the short in my wires. Now Im getting code 11, and code 14 though....fml
