No heat but blower blows
te72
Classifieds Moderator
6,611
7
WHYoming
Also, that heater valve on the firewall has a habit of sticking, or at least mine did on the 88 I had. Try pumping it by hand to make sure the the little metal bar on the bottom of it (should be easy to see what actually is supposed to move there) can move. Push it up a few times, see if that helps, always did for me. Sucked starting the car up in ~0°F weather, letting the car "warm up" and having no heat when you get IN the car...
spooln30
milwaukee,WI
Usually its the VSV for the heater control valve that fails. Simple fix for the colder months is to zip tie the valve open then when the warmer weather comes clip the zip ties. Cheapest and easy fix.
te72
6,611
7
WHYoming
Good idea! Seriously... why didn't I think of that? I carry zipties in my car as a principal, and I couldn't think to do that? :p
