well here is the deal, i didn't even know about the efi fuse which was out but i am not getting spark, the security system has been by passed but i am afraid that the cranking of the motor so many time might have locked the ecu down, so what now with no spark?salomon68;1183907 said:yeah, some more details would be very helpful. what makes you think you're not getting fuel?
when I had this problem I started with fuses and relays. they checked out good so I moved on to the fuel pump and that was my problem.
tsparks01;1184717 said:well here is the deal, i didn't even know about the efi fuse which was out...
isnms;1185067 said:No EFI fuse = no ecu = no igniter, no spark![]()
jdub;1185788 said:No fuel injection either.
isnms post#7;1184974 said:no EFI fuse = no fuel pump, no ecu
yeah i did..it works...but i have some other issues, but thanks bro, it helped allot.isnms;1185826 said:Which you can't have without a pump
tsparks01 - Did you replace the fuse? Do you still have issues?
jdub;1185788 said:Fixed
