No boost 1jz Help
supramk3man
414
kentucky
The other morning going to work i noticed i didn't have any boost, the boost gauge goes to 0 and that is it. If i kick i get 1-3 psi and nothing more. i have no check motor light on, i check all the ic pipes and all is tight and good there. the turbos sounds fine no bad sounds and no smoke. when i get on it i can hear a lot of air rushing sound but just like the boost is being let out or something. I have a factory bov and a hks ssq bov. any ideas? It just started doing this out of nowhere. the morning it started this it was very cold around 18-20 degrees.
Look at the threads at the bottom of this page and see if any of those help you. Usually the problem is either a boost leak, wastegate is stuck open, or bov is leaking.
tavarish
Jersey
I'm having the exact same problem, it feels like there's a loss of spark everytime i want to boost.
I'm going to do a boost leak test tomorrow, and check my coilpacks.
if it's not that, i'll check the wiring, something may have come loose.
tavarish
Jersey
supramk3man;1188463 said:
let me know what u find out
no problem. I've had issues with my ignitor before, and this kind of feels like the same sort of thing. I dont know why it would just die out of nowhere though.
I took out the car today, and ran like crap. I hope it's not another ignitor issue, it'll be my second in a year.
tavarish
Jersey
drove the car this morning, drove perfectly fine.
I'm going to check my coilpacks and test for boost leaks today.
I think it was because it was raining yesterday, and was very damp outside. Couldve caused a short somewhere.
