nissan powered FTW:)... my new DD
supraGhost
212
PA
Isphius;1091482 said:
ive always thought a 3sgte would go nice in one of those. or a small block! Awesome/very unique swap tho. How fast is it? thats a 220hp motor right? and that car cant be more than 2900 with it. Also make sure you check your fuel pressure. That would give it away before any codes.
yeah 222hp stock at the crank. only mods are intake and exhaust. the car weighed in at 2700lbs with a full tank of gas. im guesstimating a low 14 sec 1/4 in the low 90mph range. the close ratio 6spd really helps! chirps third everytime!
Isphius
Supra-less :(
May 30, 2006
359
long branch
sounds like an awesome ride. I want an FC, even with the rotary. It isnt too far off from my 924, really. About the same size weight and power. I would also like to put an audi 1.8t in there or a vr6. It hard cause of the front engine/rear trans setup
