New to the market
Tbo_timesupra21
4
L'ville, GA
:1zhelp:Sup ppl,
I'm new to the supra/world and been looking around for information on the cars mainly. i read-up on wiki that the head studs shud be torqued to 74lb-ft. so is that on all cars. also i want to buy one next month(an N/A less probs rite?) and im lookin for common prob's with the car, amd wat to watch for.i want to start wit an N/A to get use to the car then turbo or 2jz swap it. if u can help me thankx u can reply or messg thankx
-Tbo_timespura21
Nomad707
Im From The Bay
Mar 14, 2007
1,039
Santa Rosa, California
just buy a turbo to start..
these things are what you need to look out for on the mk3 7mge-gte supra's
-Blown headgaskets
-Rod Knock
-R154 (turbo tranny) tends to be hard to get into reverse sometimes.
-Turbo shaft play
-Turbo seals (does it smoke??)
-Leaking or seeping valve cover gaskets (easy to replace, and cheap)
I'm sure some other members will budge in and add a few things.. good luck on your quest for a supra.
Tbo_timesupra21
4
L'ville, GA
-Blown headgaskets
-Rod Knock
-Turbo shaft play
thankx for the help lol i bet having a turbo will be mre fun. the reson y i wantd to go N/A someone told it would be easier and less potential for problems. I read its hard to find headers that give max HP is that also for turbo manifolds?
TRACKMKIII
464
Atlanta,GA
Hey man its good to see you found the forum. Like I was telling you at work I would just go with a N/A since you don't have alot of cash to burn and you are still learning about cars in general. The N/A will still be fun to drive especially compared to your v6 mstang!! If you have any question or need any help you know where I am at
Tbo_timesupra21
4
L'ville, GA
yea u right i dont have a butt load of cash to just fork over but i will deff buy me the SUPRA not sure wat yr i have like 850 by dec 10th so if any1 one have one to get rid of, swing it by me
woodytsi
405
spring,tx
i just found a black 89-92 turbo here in houston. don't know the price yet but i'll check.
woodytsi
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
even the W58 can be hard to get into reverse... its a habit in any manual car i drive i go into 2nd or 4th before i go into reverse... and its works everytime. and if it doesnt, i just put it into 1st and let the clutch slip a little to get everything to move inside.
on an N/A, the potential for fun is the same as a turbo car, it just drains your wallet less. because there basically the same car, the turbo and n/a. they both need serious attention to the stock suspension, cause it just flat out sucks.
plus its nice to "learn" the supra on an n/a.... plus its not quite as picky as a turbo car. boost leaks causing fuel cut, old couplers, worn out vacuum lines, clogged lines...
just find a nice looking car... but for 850, i dont think you'll like what you will end up with.
