New to Supra's (And Turbo's), problems (Bov related.)
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
if you had a hole in the piston you would have ZERO compression and you would be blowing oil everywhere... his rings just arent sealing. but detonation can destroy rings too.
Chinois
12
Moncton, New-Brunswick
Yeah the motor was suposubly rebuilt maybe 60,000 miles ago, it has a total of 173,000 miles on the body tho.
Put some oil on the piston that is at 40, oil was shot back through the following piston, so like I said I think its a bhg, right in between both those pistons.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
yeah that would make sense actually.... you should check the torque on those two head studs in the area of the BHG, they might have came a little loose.
but yeah, if you pot oil in one piston and it shoots out the one next to it... thats a BHG...
