New speedo cable - oil required?
spiller
582
Australia/Chicago
I've got a complete brand new speedo cable assembly here ready to fit. I've read in some threads on here that it needs to be lubricated? IS this the case with a brand new toyota replacement or is it pre-lubed?
if not, what kind of lubrication is required?
cheers
Koenigturbo
1,338
Oxnard CA
I would call the dealer just to make sure. I would use graphite, but that's me, someone here, is gonna tell you different. (I bet)
supra90turbo
shaeff is FTMFW!
32
MA, 01440
They do not require lubrication. The cable itself has a sleeve (teflon?) that slides smoothly inside the steel cable sheath.
Lubing them is an option to make an old cable spin freely again. I lubed an old one of mine using new gear oil.
You can do it to your new one if you want, but I wouldn't bother.
spiller
582
Australia/Chicago
thank you for your input guys! one less thing i have to think about. my basic build has seemed like an endless journey of soucing tiny shitty little lubricants, washers and odd parts and its all adding up/taking up time! that's supras i guess...
