new head gasket right for me?
speedfreak
SCruzer
May 16, 2006
109
santa cruz, ca.
hi all i just got a mhg thats 86mm bore my 7mgte has never been bored over this is a dumb question but did i get the right mhg or do i need a 84 mm bore?
Fozbo
7M Love
Apr 4, 2005
290
Norman, Oklahoma
If I remember right, an 86 mm head gasket will work. But that is really preferable for when the block is bored over. I predict that you are going to get a lot of "it will work" type responses, but a stock sized head gasket might be a better choice if you can change your order.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Isn't stock bore 83mm? At least it is according to page EM-75 of the TSRM.
In any case, I believe that the oversize gasket will work fine, but I would rather get the correct one myself. The 1-1.5mm lip around the cylinder bore may have some effects on the combustion chamber, and will provide a toehold for combustion pressure to separate the head and block.
