Need Toyota Part Numbers Identified
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
As bad as this may sound, I cannot for the life of me figure out which bolts go where.
I made an order with Elmhurst Toyota for:
Trans mount to support member
Trans support member to body
Engine mounting plates to body
Driveshaft carrier to body
Differential housing to subframe
Intercooler to body bolts
R154 inspection cover plate to transmission bolts (both sides)
R154 support wings to transmission bolts (both sides)
R154 support wings to engine bolts (both sides)
Oil cooler to body bolts
Part numbers I was given are:
91611-61020 Bolt, W/w x4
90080-11228 Bolt, W/w x4
90119-08a87 Bolt, x2
90119-10217 Bolt, W/w x2
90119-14034 Bolt, W/w x2
90119-12100 Bolt, W/w x2
90080-11230 Bolt, W/w x3
91612-g1040 Bolt, W/w x2
91651-61040 Bolt, W/w
90080-11340 Bolt, W/w x4
90119-10315 Bolt,w/w
91651-g0614 Bolt, W/w x2
90080-11225 Bolt, W/w
Please :1zhelp:
Jeff Lange
Administrator
4,927
19
Sunnyvale, CA
jefflange.ca
I'm looking into this, however what are the "Engine mounting plates to body" you speak of?
Also, what exact month was your car made? I want to give you a list of everything you wanted, then hopefully you can go from there.
Jeff
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Jeff
According to Curt:
Curt Aigner;6983121 said:
The 2 long bolts joined by a plate, hold the subframe to the frame rail. One part number per side.
I think I was referring to what hold the engine mounts to the body lol
April of '88
Jeff Lange
Administrator
4,927
19
Sunnyvale, CA
jefflange.ca
That's the problem, the engine mounts bolt to the subframe, not the body. There is nothing that holds the engine mounts to the body, because they don't mount to the body, lol.
I know what you mean now, but it's the subframe to the body, not the engine mounts to the body, lol.
I'll check the rest.
Jeff
Jeff Lange
Administrator
4,927
19
Sunnyvale, CA
jefflange.ca
Original Part Numbers, Supersession Numbers in Brackets (These are what you would have been sent). These are the correct parts for an 88 car, some changed for 89+.
Jeff
91611-40814 x 4
(90080-11228)
90119-08177 x 4
(90119-08A87)
51229-14040 x 2
90119-10217 x 2
90119-14017 x 2 - Front Bolts
(90119-14034)
90179-12020 x 2 - Rear Upper Nuts
90119-12100 x 2 - Rear Lower Bolts
91656-40618 x 4
(90080-11230)
91611-40814 x 4
(90080-11228)
91651-61040 x 1 - RH Upper Bolt
91651-61035 x 3 - RH Lower Bolt, LH Both Bolts
(90080-11340)
91611-61028 x 3 - LH Rear Bolt, RH Both Bolts
(90119-10315)
91651-61035 x 1 - LH Front Bolt
(91651-61040)
91656-40618 x 2
(90080-11230)
Jeff Lange
Administrator
4,927
19
Sunnyvale, CA
jefflange.ca
As far as I can tell, you *should* have been sent the following:
51229-14040 x 2
90080-11228 x 8
90080-11230 x 6
90080-11340 x 3
90119-08A87 x 4
90119-10217 x 2
90119-10315 x 3
90119-12100 x 2
90119-14034 x 2
90179-12020 x 2
91651-61040 x 2
But I think Curt probably sent you some 89+ stuff, which will probably work fine, but some of the part numbers may be different. Like the oil cooler bolts, which on the 89+ are 91651-G0614, which I noticed in your list.
Jeff
