Need to plug coolant return located between first 2 runner on intake manifold
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,250
Charleston, SC
I should have done this a long time ago. Problem is, I never noticed this coolant return until I was looking at some pictures here on the forums.
I realize that the easiest thing to do would have been to just run a line from the coolant pipe that wraps around the back of the block to the return in the head; but unfortunately I already plugged that portion of the line. Permanently.
The lower portion of the intake manifold is already installed. So what's the easiest way to plug it? I don't want it to leak. Can I get by with something like a hex plug? Is the thread npt? If so, what's the pitch?
Halsupramk3
444
Mississippi
if your talking about the coolant coming out of the head and to the tube on the lower intake i tapped the hole in the head and put a 1/8 npt hex plug in there flush as mentioned above. the line on the rear i put a piece of collant hose with a bolt on one end. I used screw clamps on the short piece of hose and put super black silicone on the bolt threads before insertion into the coolant hose.
no leaks.
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,250
Charleston, SC
Looping isn't really an option right now. However, if I plug the return at the lower intake manifold, will it leak where the manifold and the head meet? In other words, does it need to be plugged on the head itself?
Van
87t Hardtop
Mar 26, 2006
974
Oak Grove, OR 97267
I capped the stock fitting with a ribber cap, installed it with a hose clamp, and applied thread sealant, then torqued it down. No leaks after doing a pressure test and running it for the past two days. Van
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
No it wont leak, the intake manifold gasket has a sealant around the hole for the coolant so you can put a plug in the manifold itself
