Need JDM non-VVTi Aristo 2JZ-GTE Wiring Diagrams
Satan
Tampa
I had the 1999-2002 JDM Supra w/VVTi wiring diagram (mostly ECU info) and we've pinned out the Aristo's (JZS147) ECU...
Which set of 2JZ diagrams are you needing? What's your setup?
s14eva1
SFL
check 2jzswap.com.........their is a section with the wiring diagram info you need for swaping it in a 240sx(silvia)
Should be easy if you do your research,goodluck
bigaaron
4,692
Pomona, CA
www.driftmotion.com
They just linked these sites:
http://www.mkiv.com/manual/manualtt/terminals_of_ecm/index.html
http://www.supras.nl/index.php?option=com_content&task=view&id=34&Itemid=50
I have been wanting to get those diagrams for a while myself Jeff, and they are not easy to find! I'll see what I can do though.
Satan
Tampa
I can't right now, but do a search for Cassio's thread on his 2J swap. The ECU is kinda widely known, but he pinned out the 3rd connector coming from he engine harness to the dash. Christian and I just traced/mapped the connector that would go back to the Fuse/junction box (from that 3rd connector).
Hopefully you'll have what you need from Cassio's diagram....
