need help
redmk3turbo
The King
Feb 7, 2009
68
Plainwell, MI
So after recently blowing another head gasket and replacing it, now it wasnt starting so after checking everything my tps wasnt working so i replaced it and now when i start the car i can only keep it running by keeping my foot on the gas it sounds perfect and will rev up but i cant let my foot off without it dieing. Any ideas ive tried doing the timing a few times to make sure its dialed in and it is and i keeping checking the tps but thats also checking out within the ohm requirements. So if anyone has a tip that would be great.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,278
69
Atlanta
When you say timing is checked, you mean you've verified the CPS tooth position?
Because it's sounds an AWFUL lot like your cps is retarded by one tooth.
mkiiichip
1,434
WI
If the car ran fine before and during the BHG, i would rule out component failure.
Start checking for vacuum leaks, unmetered air leaks, vacuum routing, ignition timing, cam timing, etc.
Have you pulled codes?
