Need help identifying a plug on a 1JZ harness going into a MKIII
Kruso
2J>7M
Jun 9, 2007
34
SugarLand
Can someone identify where this plug goes to, it is located near where the fuse box is on the MKIII, its coming out of the engine harness.
Kruso
Kruso
2J>7M
Jun 9, 2007
34
SugarLand
Thanks for the response OneJArpus, thanks to your help I was able to get that far but how/ where do you wire in the a/c wires into the EA2 connector? I'm actively searching for the answer on this board but if someone else knows it from top their head please advise.
Kruso
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
This is used fro Hydro fan as well. The A/C the Alternator wires for dash and stuff are also int here. Its the 12 pin connector. Here you go bud, hope this helps.
1. Black - Yellow +12 v EFI unswitched
2. Black - Orange M-REL EFI main relay
3. light green OPT, water sensor in rad
4. Blue / Blue - Red A/C speed sensor
5. Black - Red +12v EFI switched
6. Black - Red To temp sensor in rad
7. Brown ACMG from ECU to clutch
8. Light Green - Red A/C speed sensor
9. Blue A/C magnetic clutch from relay
10. Yellow - Green Charge warning light alternator
11. White AM1, ALT +
12. Black - Yellow to Alternator from engine / gauge fuse
