Let me start by telling you about the car. I've got an 1987 supra 7mgte auto, after about a year or so of chipping away at the various problems I've had with the car I've finally got it close to running condition. I tried to start her up it cranked and fired up. It was having trouble maintaining idle and the head lights would dim. I feared either the battery or the alternator was bad. Thought about just pulling the alternator for a reman'd one and replacing the battery but I wanted to check if they were bad first. So I took the volt meter with the car off battery charge was sitting at 12.25v, with the car running it read 14.6v so all seemed well except I had to hold the accelerator to maintain idle to get a reading.
Then I wanted to check if I had a short, so I disconnected the negative terminal hooked up the test light and sure enough it lit up. I pulled every fuse one by one but the light stayed on. No check engine light on. I'll see if I can pull any codes tomorrow just got off work and a little tired and sore especially having to snake my way around the steering wheel to get to the fuses. What else or where else should I look? Also any suggestions on the idle problem?
