need a part # for these gasket
spoolint78
Representing T.O
T.O
anyone know the part # for the gasket that sits behind the timing belt case?
Its pictured here.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=EM&P=63
I got the part # 11312 no.1 11312 no.2
I'm not sure if thats correct because i only though it was 1 gasket.
Secondly, I need the part # for the gasket that connects the coolant pipe that wraps around the block to the front timing belt case (kind of looks like a o2 sensor gasket).
thanks guys
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Alright the coolant pipe that wraps around the block gasket number is 9613-51300 this is for the 7m-gte
Now with the gasket numbers you found are "correct" there is a no.1 and a no.2 and sadly they are the same number, if you want the I have the 3 gaskets you need, 25.00 shipped to where ever you are. If you get these from your dealership then these are indeed the correct numbers to order from your Toyota Dealer hope this helps you if you want my gaskets let me know I can send today if you want
