need a map for stinger setup checked out
boostindoo
179
raleigh
i just got my car dynoed and i thought the numbers were ok, but now after checking other cars out im wondering. i got 1jz, 61mm turbo, stock injectors, stinger. i know i wont be making much but maybe should of been more. i made 279hp and 262fttq @13.3psi. my ar's look were 11.21. it was 101 degrees and 16% humidity. this is the first time this tuner is tuning a stinger. could someone please check out my map and see what u think? thanks. how do i post it or send it?
boostindoo
179
raleigh
ok got it, just change the end to em4 to look at it in the stinger program
  • jdogtune - Copy.txt
It's not going to be safe to make much more power on stock fuel. Isn't the stock injectors 330's?
Have you checked out the stinger thread. There are a few maps in there and Rakassan has a 61mm turbo as well, so your maps should be similar. I think he has 440 injectors though, I can't remember.
blackmaxx96
19
Sanford, NC
Yeah, those numbers seem low to me.
I have full 3.5" exhaust/intake/Mines ECU and everything else is stock and I put down 301WHP and 289TQ.
The Mines ECU doesn't even up the boost at all, just timing/FCD/BC/SL
boostindoo
179
raleigh
i got the car running better now, turbo hits full boost under 4000rpm. i dont know what it was but i tightened up a ground wire, gutted my cat, and moved the map sensor vacuum location. it had horrible gas mileage and turbo as u can see was hitting full boost at 5000rpm. now im getting 20+mpg getting on it. it just feels so much better. gonna put in the usdm mkiv 550cc and redyno. probably somewhere else not at the same place, theyre not to familiar with the jz motors, honda shop.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
Where was the MAP hooked up to before?
And what sort of duty cycle are you running on those injectors making that sort of power? I dyno'd 315whp on stock twins, but I was hitting 95% duty cycle on the injectors.
